will the dc2 suspension fit in a da, if not is there anything i can to make it work. thanks
to use dc2 suspension, you would just need the dc2 front forks and dc2 rear control arms (i believe you don’t have to necessarily swap the control arms- not 100% positive but unless you plan on using type r application suspension, you must use jdm type-r control arms). Everything bolts up and by doing so, you actually lower the car 2.5 inches, since dc2 struts are shorter than our DA struts. The only problem you may encounter is that since girth of the dc2 strut is thicker thus the front fork is thicker and this can at times cause the axles to rub against the forks (i’ve seen people grind down the front to eliminate the rubbing issue). But besides that, by doing so you open a new door of selection of coilovers…especially the goodies all the way in japan. lol.
-Jon
[QUOTE=AV turn’d DA;2153417]to use dc2 suspension, you would just need the dc2 front forks and dc2 rear control arms (i believe you don’t have to necessarily swap the control arms- not 100% positive but unless you plan on using type r application suspension, you must use jdm type-r control arms). Everything bolts up and by doing so, you actually lower the car 2.5 inches, since dc2 struts are shorter than our DA struts. The only problem you may encounter is that since girth of the dc2 strut is thicker thus the front fork is thicker and this can at times cause the axles to rub against the forks (i’ve seen people grind down the front to eliminate the rubbing issue). But besides that, by doing so you open a new door of selection of coilovers…especially the goodies all the way in japan. lol.
-Jon[/QUOTE]
nice, i’m definitely going to look into that. I can get a good deal on buddy club n+ full coilovers thats why im asking, thanks man as soon as i get it done im going to definitely post pics.
Hopefully i can get everything done by the 27th for the road course in englishtown, I’m picking up another DA today for a daily driver/track car, this will be DA #5 for me and integra #6.
im running buddy club n+ for dc2 and love them, my only complaint was that at full height the rear was still almost tucking rim on stock 14’s, no effin joke.
so i had a machinist buddy make me a set of aluminum 1.5" spacers for the rear. that put me right in the sweet spot.
this is what i had made. i just pounded the little bolts out of the oem top hats and used the longer hardware, the only bummer is now you have to jam a wrench in between the coils to tighten it down. but hey it works
i ran into the same issue. with Function and form coil-overs, the rear was on the last 4 threads and still tucking the top of the tire.
rear all the way up + nose all the way down = level height, but super low.
