[QUOTE=PMI;2321956]Yeah, thanks, I think
Let’s see… a conventional O2 sensor output is some kind of alternating waveform, which represents the changes in the air-fuel mix, around the ideal 14.x-to-1. If the O2 sensor reads lean, the ECM enriches the air-fuel mix, and the output of the sensor changes state. So, I would guess that if there is a steady-state output after some period of time, high or low, the O2 sensor is out of range (?)
[/quote]
while that would throw a code, the o2 signal will typcally not reach the specified ranges for a given time, programmed into the ecm. say, above 700mv, and below 200mv. the voltage will still rise and fall tho.
Although I understand how the O2 sensors are used on OBDII cars, on this car, not so much. So, do we even get a CEL if the O2 is getting old or dirty?
yes. the ever popular code 43. fuel supply fault. really just a blanket for everything involving the fuel system lol. this goes back to the question i’d asked. how does the ecm know if the o2 is at fault? or whether we are indeed jst running lean? these early ecm’s don’t know. they just see it as running lean even though injector PW is near max…fuel system fault
Can a bad coolant sensor prevent the ECM from going into closed-loop on this car?
a bad ect sensor won’t prevent closed loop on any car. it is solely the o2 sensor’s ability to create a voltage reading from oxygen content that determines whether or not the ecm can initiate closed loop. on a heated o2, this takes place within about 30 seconds after starting the engine. long before the ect has reached operating temp. in fact, it’s that cold start that really prompted the institution of the heater circuit in an o2 sensor. cold start is when the most CO emissions were being dispelled. number one cause, excess fuel to combat HC dropout. being able to enter closed loop in such a short period, on a cold engine, lowered CO and HC emissions immensely.
ect, tps, map, etc…are inputs, of course. but the o2 alone allows closed loop.
The OP had a fouled plug, and now his mileage is down even though the car runs and idles ok. So, if the O2 sensor is dirty b/c partly burned fuel went into the exhaust when the plug fouled, his engine may be running open-loop for the simple reason that the sensor is not reading correctly.
(PID loops may be over my head :D)
could be, sure. easy enough to test. while a lab scope is the ideal method, because you can check cross counts and hashing, a dvom will suffice to at least range test it
