i did swap in my 93 gs with b16a, when i get on it my car smells like fumes why is that could it because i am not using my canister is there a way too plugg it up
you are going to have to explain this better? gas fumes? canister?
jim
if it’s the charchol canister under the hood… I think you’ll want to somehow hook one up. I had a similar problem on my stock b18a and had to replace it. It took care of the fumes. You may also want to make sure that all your exhaust plumbing is tight too. If that still doesn’t solve it, get a pressure test of the gas tank to see if the system is tight. (I actually had a hole in the top of my tank at one point… scary).
-Peter
