Difference in Auto/Manuel B20 ???
Hey im looking to put a B20 into my 91 Teg which is 5-speed
well i found a motor i want to buy the guy said its from an automatic
i was wondering if it would still go into my teg w/o ne problems
or would i have to switch some stuff
ne help would be good
thanks
mike
I have an automatic b20z in my 92. All that’s different that i can remember is the flywheel. Just use your old one along with the obvious stuff that you need to transfer over and it would be fine.
I am wondering though if there’s a difference between the auto and manual cams.
use the flywheel from the b18 to the b20
ummm… i was positive they didnt make standard CRV’s :confused:
They made standard CR-V’s, they are just rare. the auto B20 has a Flexplate, not a flywheel. The cams should be identical because the motor was tuned from the factory to produce excellent low-end, something the auto model would need.
make sure you use the flywheel bolts off your b18, NOT the bolts from the b20. the b20 will say AT on the bolts and the b18 flywheel bolts will say MT. the AT bolts are shorter than the MT b/c the flywheel is thicker than the plate from the auto tranny
mike, i didnt even realize this was your thread. gimme a call if you have any questions
allright man thanks
i think im getting an engine
he said its a 99-00 B20B
under 30,000
comes with everything except ecu and tranny
he wants $500
