ef rack swap witch tie rod.
I have seen all the threads with the 91 crx SI manual rack conversions but no mentioning of the outer tie rods. do i use Integra tie rods or civic? need to know this so i can get all the parts together. thank you.
I used ef inner tierods, but im sure you can use the da inners aswell.
So you used EF Inner and Outers? im more worried about the outers i figured i would have to use the ef inner.
I used EF inners and DA outers
The outers are the same between the two
From my understanding the EF and DA front suspension is almost all the same…
Alan
i wasnt sure with the us ef, jdm ef and DA knuckles being diffrent this is why i wanted to make sure.
