How do you take off the front Acura emblem and the LS and other emblem in back? Need some ideas. Thanks
how to remove
I just used a plastic tool to pry them off; dont use metal unless you dont care about your paint; KMart or Fredmeyers has stuff to take the extra sticky stuff off; btw i also used a heat gun VERY CAREFULLY!
easiest way i’ve found is with some fishing line or dental floss. Just run the line behind the emblem and pull back and forth on the line…the emblem should come off pretty easy (you may break a couple pieces of dental floss though…monofilament is stronger).
dental floss:up:
Originally posted by siccnicc23
dental floss:up:
and a hair dryer.
Hey guys are there holes under the front emblem? Previous owner has an aftermarket emblem up front and it has to come off ![]()
Goldfingiz
Originally posted by Goldfingiz
[B]Hey guys are there holes under the front emblem? Previous owner has an aftermarket emblem up front and it has to come off
Goldfingiz [/B]
yes.
