To get the most power to the ground possible I’m trying to decide on an engine swap.
I was thinking either H22A or JDM spec Poor Man’s ITR. Which of these would have more power after complete engien work (built up, mechine work, turbo, ecu…everything)?
Which would be more cost effective and easier to set up?
If you can post a short list of what mods should be down to get the most out of either engine.
which will have more hp is easy----the h22. Think about it 2.2l vs 1.8l Pretty much automatically the 2.2l should yeild a good deal more hp—same goes when it’ll be fully built.
the poor man’t itr will be MUCH more cost effective and MUCH easier to do. Putting an h22 into a G2 is not an easy task. Its both difficult and expensive. Personally I don’t think its worth the work. If you want more displacement, just build a crvtec.
