Hi there,
I’ve noticed in my 93 Integra GS that I’ve got a lot of play on my stick when it’s in gear. IE when you’re in neutral you can move it back and forth a lot (obviously) but when I put it in ANY gear I still have a lot of movement. IE I can move it back and forth. MY girlfriends 92 GS-R has almost no movement at all. Is there an easy way to make it so I don’t have so much play? What might be the cause of this?
Also when I shift into 3rd (only 3rd) I get a small grind just as I do it. It doenst’ matter if it’s warm or cold. It only really happens if I shift medium to fast. Rev’s don’t seem to make a difference in whether it grinds or not. Can this simply be fixed by replacing the fluid?
