extremely strange cold starting issue
Ive been searching for the last few days and came up with nothing so recently as it has been colder out for the last three days i have been having a weird starting situation i will put the key in, move it to the start position and wait till i here the mfr click then i crank it, it starts then kinda sputters for 2 seconds then dies it takes the dash lights like 2 seconds to come on after it dies its kinda like the car reboots or something, then i go to start it again and it starts perfect like nothing ever happened and continues to run fine the rest of the time it only does this after the it sits for a few hours im kinda stumped. The distributor is a little more than a year old and is oem installed by an acura dealer the battery is brand new and all the grounds have been replaced with 4 ga ground cable with clean contact points. i started to have this problem only a few days ago when the temperature dropped below 40 tomorrow i plan on checking the MFR relay solder joints and doing the tests for it and i am going to take a look at the IACV and the FITV i feel like its a fuel related issue but not sure if anyone could help i would be greatly appreciated thank you so much. Oh yea its a 91 Integra RS automatic trans.
put a bottle of that isopropol (sp?) alcohol stuff in the tank. sometimes called Heat. with the temp change it could’ve built some condensation in the tank and so there a little moisture in the system.
about the best i could suggest for ya
aight thanks for your help
