F20b DOHC Internals in h22a (220 hp version)
Hi,
I just got hold of a dirt cheap complete h22 swap with a defect rod bearing that has killed the crank as well. But I have a f20b dohc bluetop engine thats just sitting in my garage so my question is, could I use the crank and rods from that engine and use them with the h22 pistons?
I know the r/s ratio will become a little higher but I’m not sure what kind of affect that will have on the h22?
h22 r/s: 1,57
f20b dohc r/s: 1,64
I think thats the only problem with swapping over the parts, the blocks are the same height,the pistons have the same compression height and the heads have the same combustion chambers.
I don’t think that’ll work. I can’t say for sure. Why not use the d series crank and rods, get some
K20a2 pistons and use the head from the h22 and build a mean g23!
I’m staying with my original plans because this is a budget build, and with a thin headgasket I think this setup will give some nice numbers.
I have crunched the numbers through several compression calculators and it all look good so I’m starting the build as soon as I’m done with some other projects.
So there is no piston, or valve clearance with that set up?
You can’t use the pistons from the h22… bore size is 87mm vs 85mm. You can, however, swap the heads. My friend swapped a h22a head onto his f20b block… only reason is because the h22a had skunk2 internals in it.
the h22 has i believe 2 extra pin hole guides in it, so to do that, you would have to press a pin in, then shave the head a tad to make it level from what i understand
