Hey guys I got a few questions. I currently dropped a B20B into my 91 Integra. We got it all situated and thought it was ready to fire up but it cranked and didn’t start. I took a look at the cam gears and the intake cam was facing at 2 o clock and everything else lined up. First question is which way does the crank pulley rotate on the B20B when it’s running? I forgot to look. Second is when I take the timing belt off how can I turn that intake cam gear to where it needs to be?Third is how do I go about tightening the tensioner? The way they say in the book I can’t understand what they mean. Last is how do I bleed the cooling sytem on a B20B? I can’t find a bleed screw. Thanks guys.
Take the spark plugs out, outter timing shields if they are on to expose the timming belt, and valve cover off. Always spin the crank counter clockwise. Make sure the #1 piston is at TDC. You will then want to rotate the cam gears until the arrows face up and the hash mark on the cams are lined up in the center. You can use some 5mm punches I belive to stick into the cam shafts to keep them lined up (check service manual for MM size of punches I forget) or use a tool from matco to hold the camgears while putting the belt on. Hand tighten the tensionor and then with a ratchet spin the motor counter clockwise and the belt should tighten up. Tighten the tensioner bolt up and you should be looking good. I alway rotate it several times after this while checking TDC and cam gear postions before proceeding.
I belive the bleeder is on the thermostat housing. Ive been working with v8s for the last few hours and my head hurts so forgive me. Check there.
Good luck.
Thanks man.
