Lately my car has a occasional “Flat Spot” on acceleration and also its been a bear to start.
Plugs, wires, cap and rotor are all fairly new. Fuel Filter is new. Is it an injector issue?
Thanks for your help in advance!
i am in the same boat:angel:
Where is your flat spot? Start, half way through acceleration? Are you stock? Does the car’s idle hunt around? Do you get bad gas mileage compared to other G2’s?
I would say check your timing, my db1 is nice and peppy, except for when I have to get it inspected, and retard the timing. Then its a dog on acceleration at the start.
when was your last “check up” on the engine? compression test, check fuel pressure, etc.
