fog rewiring problem
ok so i decided to rewire my fog lights today . i took off the switch covers and popped it out and then i spliced the r/y and b/y wires. i connected my battery and then tried em out… didnt work at all.
does anybody have an idea as to what the problem could be? maybe the wrong wire was used. i have no clue. . . . thanks
Did you connect them backwards, such as splicing the defroster into the fog lights instead of vise-versa? Does the defroster come on at all, and do your fogs work at all,m even when the lights are on. Also check the fuses.
thanks alot ive found the solution to my problem. . . .:cool:
