Kicking butt at Willow Springs this time!
Damn, good luck on Round 3…still wreaking havoc on the CRXs in H4?
Hey itaintegrals, great driving by the way. Anyhow, what do you think about staggered tire sizes, and running a wider tire in the front for more oversteer, or wider tires in the rear for more understeer? Are you running 225/50/14 in both front and back?
Also, can you strip your car down even further, to get below 2500 lbs?
I’m curious: why you’re using a stock front sway bar, and an 22mm ITR rear sway bar?
Also, are you using strut tower bars? If, which type, and what material is it?
I know these are alot of questions, but also what ECU program are you running to modify your fuel map? Are you running slightly lean?
Thanks for any replies itaintegrals! I’m slowly building my car up, and I’d like to get advice from an actual racer, who has experience, and knows what works, and what’s just hype.
And good luck with your future races!
-Andrew D.
I would like to see a similarly modded DB2 running in this class… What do you think you could do with another 30 or so HP in H4?
You would be kicked out of H4 thats for sure. And maybe kick some H1 cars butts on the way.
Minimum weigh for my class for a DA is 2480lbs so no more weight reduction.
I keem all for tires 225-50-14 for faster cornering more grip. I use stock front swaybat for stabilty and a ITR rear bars to the rera end will get loose when i want it too slight oversteer. Cheap front tower bar and rear is made with the cage. ECU is a custom program made specifically for my car.
Is that just the car or car + driver?
What exactly are the rules for H4? They won’t let stock Vtec cars run? Is there a HP cap?
Here is the national rules for Honda Challenge. Its good to know the rules.
Check it out guys
Db2=h3.
whens round 3, im lookin forward to the vid… just wondering
Round 3 is on top of this page. Round 4 is in 2 weeks.
or click here
Round 4 this weekend at BRP June 5-6. Wish me luck.
Good luck…
so how’d ya do? get another vid?
HAd some electrical issues the car wouldent rev and it like hit the rev limiter at 6k rpm sometimes.
Whole race video from inside the car #78 H4 Integra Edik Stepanyan.
June 6, 2004 race at BRP WCHC.This video will be up only for a few days.
114 megs , Video is good quality right click and save. 56K will take long
Finishing position 2nd in H4. Electrical problems kept me from winning.
Video
http://webfiles.uci.edu/hstepany/RaceVideo/WCHC%20June6%2C04.wmv
PICS
The rest of the photos can be found at this link.
http://webfiles.uci.edu/hstepany/BWJune/full/
omfg I like your bandwidth :drool:
anyway… nice! what caused the loss of control near the end tho?
the link doesnt seem to be working… is there another host somewhere?
Kiwi sends his love and promises to stay away from you on track
sorry to hear about the electrical probs congrats on doing as well as you did with the probs though
hope its cleared up by the next round, when is the next round?
