I had a hunch that was it. Nice work by the way. Did the cap the ends? Secondly, did you double-side tape the door sealer to the side or to the bottom of the bumper? I have the parts in the garage (doesn’t cost much) but never got to start the entire work.
all i did was use some automotive goo. measure out your garage door sealer and cut it to measurements. glue it onto my 91 front lip, and that’s it. i spray painted the lip gloss black. glad you like it.![]()
here’s a pic of my stock 90-01 lip…what do you guy’s think!!!![]()
[QUOTE=db1st;1970768]hahaha38…i have 89 integra front lip on my 91 integra…it is pretty accessible, you can basically find it at any junkyard (i got mines for about $6 at pick-n-pull). all the bolt holes from the 89 front lip matches up so there won’t be many modifications on the bumper or the lip other than you having to trim down both ends on the lip so it matches your bumper. if you’re thinking of doing this for your car, i suggest for the best results you use longer bolts(2½ in.), washers, and plenty of nuts(i used about 30-35nuts, no joke!!!) to help adjust the lip for proper fitting and to lock everything down.
here is the lip on my car just bolted up w/ the original bolts…as you can see it sits too far up and there are gaps at both corners of the bumper
…and here you see this is how it looks like after spending more time on installing it using extended bolts and all those nuts!!!
im not sure if this is what you’re looking for but…hopefully this helps a little. in my opinion, it doesn’t look too bad, almost like the JDP lip…ALMOST!!!.[/QUOTE]
i have a DA1 lip on my DA as well…
looks alot better now that you took the time to install it right :-)… very nice custom!!!
anyone know where i can find a bra like that one? with integra stitched in… looks good!
You can get them at the dealer for about $70 or there’s a member on here that’s selling them for $75 shipped… do a search on the forsale forum…
ACURA INTEGRA NOSE MASK (HALF)
Part# 08P35-SK7-201
Correct?
And then the hardware kit for mounting is
ACURA INTEGRA NOSE MASK HARDWARE KIT
Part# 08P35-SL0-200R1
$57 for the hood bra, $3 for the hardware kit
Its under accessories
anybody know where i can get the fender covers???
No front “lip” here. Back in 2001 I hit a deer at high speed and it destroyed the front of my car ('90 Integra). Had to piece together the front of my car on the cheap. Ended up using an inexpensive made-in-Taiwan aftermarket bumper cover and the factory “lip” wouldn’t even bolt up properly so I tossed it in the garbage. Have never missed it. :sleep:
JDM ITR lip
[QUOTE=YUNGSTER323;2014844]here’s a pic of my stock 90-01 lip…what do you guy’s think!!!![]()
i think it looks
stock
heres my car with the chargespeed lip
i say Hiro or chargespeed or oem only ![]()
Lover Souls. :inlove:
they come with the half mask for 92-92 integra , so does the mounting hardware , i got my nose mask for 47 bux shipped to my door
Where can you get that ghargespeed lip and how much i love it
$325.00 + $45 shipping @ jdmcarboy.com
JDM CARBOY Exciting Car Shop! – JDMCARBOY
CD Accord lip… pull-apart. price = FREE! Got tha hook up.
:rockon:
damn that lip looks good, ima toss my “type r” one for that bad boy, ima go to pick your part tomarow:rockon:
any thing i should know while puttn it on?
