Fuel Filter install -- Banjo bolt align
Tried a search, couldnt find anything…
Installed new fuel filter today, just wondering if the hole through the banjo bolt needs to be aligned a certain way? Does it matter? I realize the Helms didnt say anything about it, but I reasoned that if the holes werent aligned with the holes from the fuel hose, it may not flow as good?
TIA
i don’t remember having to do any specific alignment when i did mine. I just put in the new filter and tightened everything back down.
after you torque the bolts down make sure you check for leaks. I tightened my bolts to spec but then it leaked. I ended up having to torque it down much tighter than specified in order to stop the leaking.
Re: Fuel Filter install – Banjo bolt align
There’s no specific way it needs to point. Just use the new washers if supplied.
coool thanks !!
