can anyone tell me where the fuel pump relay or fuse is i just installed a new fuel pump and i still wont start. please help!!! :mad:
The main fuel relay is under the gauge cluster. You’ll have to remove the plastic cover on the driverside under the steering column to get to it. I wish I had a diagram, but I don’t. You should be able to see the relay once you remove that plastic cover.
thanks ill try and find it
