I looked under the Teg tips to reset my ECU. It says to take the 7.5 fuse out and put it back in after 10 seconds. Wheni went to do that guess what? there wasnt one and i also noticed that there were three fuses missing meaing emptly slots. Is this OK or are there suppsose to be fuses in each spot and what about the 7.5 fuse? I have a 1992 GSR… ill try to post pics if i can, dont have a camera right now.
Also can anyone send me a fuse diagram for the fused under the hood. Thanks
You have a canadian model Integra. It’s even written in the teg tip that there’s a 10A fuse to remove instead
"According to the Service manual the ECU reset procedure is the following:
ECU Reset procedure. (Perform every time when troubleshooting)
Turn the ignition switch off.
Remove the BACK UP fuse (7.5A) from the under-hood fuse box for 10 seconds to reset ECU. [SIZE=5][SIZE=4][SIZE=2]CANADA: Remove the HAZARD, BACK UP fuse (10A) from the under-hood fuse box for 10 seconds to reset ECU[/SIZE][/SIZE][/SIZE]"
You could always reset i the old fashoned way, by disconnecting the battery.
That will kill your radio presets though. If you have a stock radio you need a code to get it to work again.
