I was thinking about starting up the G2ic monthly calendars since no one does them anymore, but what are the most common resolutions? I was thinking of making one wide scree version and one standard, unless there is another style? Maybe I can just make the largest resolution, and then people with less res can just have it squeezed down, although the quality would be a bit more poor that way. Anyways, the big question is what is/are the most common resolutions.
I’m using 1280 X 800. I do miss those calendars.
ohh, start it up again! lol
im picking up the jdp rear visor today,
but… im not going to be putting it on anytime soon, but i will be tempted.
anywho, i should be going photoshooting more often since i havnt done it in awhile, so my pix should come in handy with this calendar.
i use 1280x800
-karlo
I’m using 1920x1200 on my laptop. Definitely would like to see this going again. 1280x1024 is fairly common for a non widescreen LCD. If you make a regular and widescreen both in a fairly hi resolution, they should work for everyone.
