got 1 pieces today...problems, *pic*
what can i do to make these wires longer, they were cut too short and i am having a hard time splicing them. the ones on the others were long enough. also are the foglight wires connected to the headlight so there are no wires to mess with as far as that gose right? and there is an extra harness in the middle of the headlight and corner, is that for the side markers? thanks for any help you guys give me.
you can soder the wires together
i donno about your other problems :slight_smile:
just use some butt/splice connectors to add a couple extra inches of wire on there. or you can solder another piece of wire onto the ends. its up to you.
splice it, solder it, buttplug it, it can be done.
from the corner lense to the fog, it goes signal wires, fogs in the middle, headlight. ya the fog wires extend to the middle not sure why
Thats plenty of wire !! What you talking about . Just solder dem shiz in man .
Deffinately solder them. Using butt-connectors or whatever won’t make the wiring as “attractive” if that makes sense.
buy new harnesses.
Go to kragen and buy two “conduct tite harness”
Part # 85810
True indeed, not to mention that the metal on the butt-connectors will oxidize easier and may corrode later on down the line.
Originally posted by 91 Frost Teg
…also are the foglight wires connected to the headlight so there are no wires to mess with as far as that gose right? and there is an extra harness in the middle of the headlight and corner, is that for the side markers? thanks for any help you guys give me.
No, the foglights have their own terminal and connection. Please see the crude drawing I’ve provided in the past as an assistance:
