Greddy Blue Box
I just installed a Greddy Blue box on my 92 Integra RS to see if it would workand wow what a difference. I got it from my buddy with a 95 Civic Greddy Turbo kit but he didnt need the blue box because he got Hondata. The car actually drives normal and I can floor it and there is no bogging whatsoever. I even got rid of the missing link and no check engine lights and my EGTs even dropped. I used to get up to 820c at full throttle and now it only goes to 780c at full throttle. I had to disconnect my Field controller though.
cool :up:
nice, what were you using before?
yeah what were you using b4?
-Toby
I was using a Field fuel controller. I could never get it to run smooth without any bogs.
the fuield controler can probably be used to fine tune someehting like the greddy fmu, but woudnt do the job it self, the change in fuel trim it can make woud be to small, it modifys ur map signal, but if ur map signal is already at 0 vac or positive pressure, then the extra signal will still be over the amount the ecu recognizes to make fuel trim positive/negative…
-Toby
