well my fan speed and hot and cold clomite control knob are no longer lit up at night when lights are on. i cant see each little dot for the fan speed nor the red and blue for the climate control. how in the hell do i fix this?
This light is very easy to replace. Take off the knobs for the fan speed and temperature control. Then carefully pry off the small plastic display. I can’t think of a better word for it, but the part that should be lit up. It’s only like 2" by 3.5". Once you have that panel off, you will see the lightbulb that is burned out. Just pull it out, and replace it. Put the panel and the knobs back on, and you are set.
let me know if you have any questions,
John
