Help me with antifreeze leek!!
Ok, I noticed a small puddle of antifreeze today, near the driver’s side front tire. So I jacked up the car and found antifreeze all along the rim of the oil pan. It seemed more concentrated on the driver’s side. I looked and felt everywhere but couldn’t find the source. Could anyone give me any idea’s where the leak is coming from??
Thank you
anti freeze
follow the anti freeze lines in the car. teh anti freeze does go around the intake manifold, so it might be coming down from there. i had a leak that way.
MaTt
hey man, check your tranny cooling line. it runs from the bottom of your radiator. its about 1/2" thick. mines split and have’nt gotten off my ass to fix it yet. i’ve got the same small puddle.:ok:
mine came mainly from a leaky water pump. it all started when i took it to vegas with teh a/c on heh. soon after a few hoses started showing wear and i still havent gotten off my ass to fix that either.
after i replace the obvious ones, im going to have my system pressure tested. in the meantime refilling with water every other day or so doesnt bother me too much
Thanks guys I’ll check those lines this weekend, it’s weird though the last day I haven’t seen any dripping, or puddles. Maybe the problem fixed itself!! Yeah right
