help me!!
its my very first time owning an acura. i have a 1991 acura integra ls 1.8 liter and i wanted to know what kind of engine swapping could i do or what upgrades should i do???
Limits on engine swap are limited to your pocketbook and access to parts.
The main question on the mods is what you wanna do with it? To just get a good basic powerband jump stick to IHE.
http://www.g2ic.com/forums/announcement.php?f=29&announcementid=13
BEFORE STARTING A NEW THREAD…
Please run a SEARCH before you start a new thread. The search feature allows you to find answers to your question / comment immediately, since it is VERY LIKELY that your question was asked before. Searching also reduces the site’s bandwidth requirements.
Should you still have questions, it is better to reply to an OLD THREAD than to create a new one.
If you need to create a new thread (such as the case with an archived thread), include a link to the thread where you got your information from and would like to continue the discussion.
DON’T BE LAZY, SEARCH FIRST!
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
thread closed due to improper thread title.
