Hi everyone,
I’ve had my one-piece headlights for about 3 years now and have had no problems with them until now! Recently I’ve notice moisture inside the right side of the headlights after leaving my car outside at night. It has never done that before. I’ve check for cracks on the headlights and checked the light bulb seals and they seem to be alright. No signs of cracking or breaking. It only happens to the right headlights and the left one is fine.
After I’ve let it dried out. What can I do to prevent moisture from getting back in? Will it affect my electrical? I guess it’s not that big of a deal, but it’s annoying. Any feed back will be greatly appriciated. Thanks everyone.![]()
Here is what I did,
Uninstalled my 1-piece that was leaking about 2 weeks ago. I set my oven to 200 Degrees Bake, I put the one piece headlight in there, I checked every 5 minutes on it…
after about 10 minutes it was ready, I took the headlight apart…cleaned the inside (was thinking of doing a Black Housing) and then resealed it…and installed it, ever since then, no leakeage…
MAKE SURE NOT TO OVER HEAT THE OVEN TO HOT!!! OR FORGET TO CHECK UP ON YOUR LIGHT!! OTHERWISE,
you are going to be eating BAKED 1PIECE for dinner bro…
