I need help… ok, I need to replace my rack and pinion boots which they are torn up on a 92 integra gs, and I have a complete redone 93 accord rack and pinion w/new boots, is it possible the same as an integra so I wouldn’t have to spend like $25 for new rubber boots. If any help please lmk thanks
are you talking about the bellows boots? if you are then those should work fine, seeing that they give protection against moisture, oils, chemicals to seal dust and other environmental elements.
why dont you pull both apart and measure both boots and see if there about the same size, if so I dont see why you cant use them.
thanks for the advice, i did some research and found out on google. product number was same as integra from an aftermarket store place on the net. but I’m going to check out the measure size too, just in case.:rockon:
