help squeaking
Hello guys i’m wondering if anyone could help i’m having a squeaking probleme and the integra is my only car to go to work i need to fix the issue fastest possible, and i dont want to change everything in the direction for nothing! also it’s getting worse everyday :S sound like a balljoint but when i like the car and shake the wheel doesnt seem to have any loose… maybe it’s the lower balljoint what you guys think?
all new energy bushing installed, and shock already replaced and still squeaking
here’s a video it’s the best for you guys help me i think!
thanks in advance!
http://www.youtube.com/watch?v=rITo3k2DUaM
yesterday i changed the lower balljoint for a OEM honda, and still getting that sound… i think i’m gonna have no choice except replacing upper balljoint
Man thats some squeak! More of a creak actually which leads me to believe its coming from the upper part of the car. Like, shock bushing, shock mount, Upper control arm bushing…Even the coil itself.
It definitely sounds like its suspension related tho.
actually i got the front strut replace, the bushing of the strut are polyeurethane energy kit same for upper control arm, the only thing i could see that is squeaking was if the bushing where kind of too dry.
So i tryed to grease them with the energy suspension kit grease and still squeaking.
The only parts i didnt replace is the upper balljoint, and i’m kind of desperated, this is kind of issue that make my think about set the car in fire
a lot of people over the years have complained about the polyurethane bushings squeaking, and then again many have not. Im not sure why there would be such a difference.
Can you hear what side of the car it is coming from? Maybe you can get someone else to drive the car like you did in the video, get right in there and try and pinpoint it. I’ve been upside down in the passenger seat in my car with my buddy driving trying to find noises before. They drive me crazy.
So yeah, try and further pinpoint it. With something so loud you should be able to get a good idea. It really sounds like its upper, I would guess coil spring or mount. Any chance you have a spare stock shock/coil kicking around? Just replace the whole thing to see if that solves it. With the polyurethane bushings they may not have been greased well enough upon install (most people recommend NOT using the grease from ES cuz it really sucks) so it may be as simple as that upper strut bushing.
It’s your upper control arm bushings… those tend to squeak the worse when replaced with ES bushings. Try to grease the fuck out of them or just go back to oem ones…
can a wheel bearing can make that strange sound like that??
yesterday i found out that my wheel bearing on that wheel was dead… i got loose on that wheel
now i drive my bmw, i just dont want to kill myself in my car
wheel bearings tend to make a grinding sound when they go bad and the sound gets worse when you olace a load on it.
yeah wheel bearings dont really make that sound in my experience. They make a scraping/squealing sound. Just jack the car up, remove the tire and turn the rotor by hand…you should feel resistance and a metal on metal sound.
Im with Hybrid on this one…Upper control arm bushings. grease them up with good grease or change back to OEM.
Another thing is if you installed ES bushings in the UCA and you didn’t preload the suspension before torqueing the bolts… you’re going to get alot of squeaks because the ES bushings are constantly twisting thus creating a shit load of squeaks…
I suggest you loosen the nuts that hold the UCAs to the frame, grease the bushings with ES grease, preload the suspension, then torque everything back up… I bet that will cure your problems…hope this helps…
i went to a friend garage today,
he check my car and he said that this sound is cause by my caster rod bushing…
it sound good for me this could be that cause when i put on the suspension with my hand it doesnt make any noise or sqeak, it’s only when start or brake.
OMG i had the bushing replace and still
still having that sound…BTW i grease every bushing again and still doing that sound!
there is no much part left before i had replace everything!
-sway bar bushing
-strut bushing (the one on the lower control arm)
-steering rack ??? could that be…
man, you have just got to pinpoint the sound…Have you tried re-doing the UCa bushing as hybrid suggested? Have you tried getting someone else to drive the car and you listen carefully to pinpoint the sound?
We cant find the sound for you, only make suggestions as to what it might be.
Yeah dude… try to pinpoint th sound. Jack up the car… take off the wheels and try to twist and shake all your suspension parts to see which one is squeaking. If it’s too hard to shake or twist… use a prybar.
Did you tighten the rod bushings to spec? Also if you say you greased all the suspension bushings and it still squeaks… you might want to also check your engine mounts bushings to see if it’s in the process of tearing since you say it only squeaks when accelerating or stoping.
