help! whistling noise???
hey i was wondering why my teg is whistling…it only happens when i turn and on on ramps to highways or when its a quick turn…its not a whine like from powersteering but more like whistling …its not the tires rubbing or anything like that…the steering is funny as well sometimes …goes hard and then soft…confused and i don’t know what to do…??? can anyone help me out?
is it a whistle or a sqeal and what do you mean by goes funny like what seems to change beside hard and soft.
its a whistle noise …and it only does it when i turn at a set of lights…or when I’m on a on ramp getting to the highway and i notice that when I’m parking the wheel tends to tense up when I’m turning at certain points …but the thing that is throwing my off is that the tensing of the wheel is not constant and to stop the whistling noise i have to take that turn very slow…for it not to whistle…any ideas …does this help?
and the car is sitting on teins s tech’s
it sounds like your power steering pump may be on its way out you could try to replace the power steering fluid to see if that changes anything. I dont want to tell you wrong info so if anyone else could please also put in some input.
Check all your cv boots. Sometimes when there’s a tear in the boot… they tend to whistle when air goes through them… just a suggestion.
Mine had the whistling sound and it turned out to be a small tear in my cv boot…
well I’m going to try it out ill let you know what is happening…just in case for anyone else who would be in my shoes at the moment…or future (knock on wood)…
hey guys just to let you know the status…i had a leak in my power steering hose…fixed that topped it off with fluid and she works like a beauty:rockon: just wanted to say thanks!
long live DA!
