i cant get it to run ryte.i bought the motor from a friend, he told me it ran fine in his hatch so i bought it n swapped it into my integra since I blew up my last b18a1 motor…its having problems…
when ever the check engine light comes on it idles like a champ,
but when the check engine light turns off then it starts idling like its struggling and about to die out…
even my cat converter turned burning red…i dont no whats wrong with the dawm thing…can enyone help thiz integra breath again
The car starts up and drives… but just has these problems…
the mods I have on it are just simple ones
type r clutch,fuzion headers,cold air intake
Help please… I want to figure this out… because it would cost me at the shop… and Im broke for the moment… thanks for the input…
I was thinking the same thing… maybe a clogged cat…
I cant pull the code now… since I dont have the access to a Diagnostic tool… and Im currently working today… but tomorrow I’ll try to pull the Cat and see if that could be causing my problems…
otherwise than that… what other possible problems could there be…
You don’t need any kind of diagnostic equipment to read the codes the ECU is throwing. Try reading the Teg Tips, or better yet, here’s a direct link to what you need, http://www.g2ic.com/tegtips/engine/13.html
