system
August 13, 2002, 6:38pm
1
Ok starting in a few weeks i’m starting my new engine. End goal will be a ls/vtec turbo running 15-20 a the track and 8-10 street. I started the list of parts i need. Not including labor cause i will be doing almost all of it myself. So heres the list. Feel free to add in prices, correct prices pr add parts i will need. All info is def wanted. I want to do it right the first time so feel free to carry on.
ls block -
b16 head - $350
Head bolts - $60
b18c5 intake manifold -
B16 ECU - $300
B18 a/b head gasket - $50
B18c5 intake manifold gasket -
Valves -
valve springs -
ITR cams -
cam seals - $15
Steal Braided Oil Line - $25
T fittings - $10
Forged Pistons Low Comp Pistons -
Connecting rods/shot peen existing ones? -
Block Girdle(z10,shotpeend) - $320
Block Pinned - $300
Vtec Oil Pump -
Vtec Water Pump -
Inline fuel pump -
T3/4 Turbo -
FMIC -
Necesary piping -
2.5 inch exhaust(Done Myself) - $100
Turbo manifold - $300
BOV -
Wastegate -
vafc -
Clutch -
since your going to be running so much boost, I would get the block sleeved, or take it a step up and buy a b20 block. you would have more horses, and torque. but your probly useing the block from your teg. just get a sleeved block.
system
August 13, 2002, 8:06pm
3
yeah i’ve pretty much decided on not getting it sleeved, hence the pinning and the girdle. I just dont want to wait the month or two.
G2guru
August 14, 2002, 6:36pm
6
ls block -
b16 head - $350
Head bolts - $60
b18c5 intake manifold - $200
B16 ECU - $300
B18c5 intake manifold gasket - $14
Valves - what kind of valves will determine the price. And you’ll have to pay a head rebuilder to seat the valves for you.
ITR valve springs - $200
ITR cams - $450
Adjustable Cam Gears - $280
cam seals - $15
Cam End Plug - $5
Oil Pan Gasket - $14
Oil Pickup tube Gasket $5
Valve Cover Gasket - $8
Spark Plug Seals - $8 (for 4)
Crankshaft Mainseal $20
T fittings - $10
Forged Pistons Low Comp Pistons - $350-$500
Connecting rods/shot peen existing ones? - For turbo…FORGED or Billet (Eagle, Cunningham, Crower) $350-$650
RC 310cc Injectors (minumum) - $360
Adjustable Fuel Pressure Regulator - $40-$150
Block Pinned - $300
Vtec Oil Pump - $150
Vtec Water Pump - $70
Timing Belt - $65
Belt Tensioner - $60
Inline fuel pump - $150
T3/4 Turbo -
FMIC -
Necesary piping -
BOV -
Wastegate -
vafc - $200 used/$300 new
Clutch - $280-$480 (depending on the clutch)
system
August 15, 2002, 7:49am
7
Anyone think this setup wont be able to handle 20lbs of boost?
Also i’m not sure if the t3/4 can put out 20 lbs. Anyone?
