How do I remove the plastic panels in the trunk of my 91 LS?
Just as the title says. I know how to get most of the plastic off, but I can only pull it back. Here’s what my trunk looks like right now:
You need to take out the rear seats to completely remove the rear quarter plastics.
There is a bolt or two but it’s mainly clipped to the body.
[QUOTE=unified112;2298191]You need to take out the rear seats to completely remove the rear quarter plastics.
There is a bolt or two but it’s mainly clipped to the body.[/QUOTE]
How do I remove the seats?
The back-cushions are secured by a bracket on each outside corner. Remove thoe two nuts first, then the inside-corner is wedged over a little metal nub. Basically you have to pry the seats out. Not terribly hard.
Once those are out, the seat-bottom is secured by one 10mm bolt and the front of the cushion has metal tabs that slide into the floor. It’s kind of tricky to slide them out but you’ll get it.
[QUOTE=unified112;2298194]The back-cushions are secured by a bracket on each outside corner. Remove thoe two nuts first, then the inside-corner is wedged over a little metal nub. Basically you have to pry the seats out. Not terribly hard.
Once those are out, the seat-bottom is secured by one 10mm bolt and the front of the cushion has metal tabs that slide into the floor. It’s kind of tricky to slide them out but you’ll get it.[/QUOTE]
Thanks. I decided not to remove these panels now though. I didnt realize that they went past the seats and up the door frame. I don’t want to undo all of that.
