how the hell do i bypass the fast idle thermo valve (FITV) for the type r manifold… im running the hose where it inputs to where the hose that it outputs go… shouldn’t this just bypass, instead i overheat easily and get a CEL…i need to check the code and i’ll repost later but how do i bypass it…WITHOUT OVERHEATING … I have plenty of radiator fluid. thanks for yer help.
anyone? im dying here! i need some help!
Yout take it off and block where it used to be with a custom plate or gasket. An instructions sheet comes with the hondata heat shield gasket.
http://www.hondata.com/heatshield.html
I will look for my sheet and see if I can scan it but I think I may have thrown it away.
while your at hondata be sure to check out this awesome drag run video.
http://www.hondata.com/media/erickincar1.mov
