how to addentifie vtech heads
I have a 90 ls n want to vtech it. My buddy has a single cam vtech that gos 7000 rpms but I want 8 plus plan to turbo later don’t see the reason to have a turbo n only shift at 7. I also worked on a 98 gs today that went to 8 how do I know what it is though where on the head do I look.
It’s “vtec”, not “vtech”.
Yes. Revs are everything. WHo cares about torque curves and power bands.
Here is the vtech website. Hope this helps.
First off You can turbo anything and it will be fast Just because a 5 liter doesn’t rev to 8000 rpm’s doesn’t mean that it wouldn’t be a great candidate for a turbo. And for the head on the top on the front side of the head there will be 3 sets of stamps. 1 with 2stamps on the left, the one in the middle has four(first one of these four will tell you what year it is which is handy to know :slight_smile: ), and the one on the right has the head code witch is what you want!
hope this helps
Be careful revving the stock b18 to 8k. Those rod bolts would be your weak point!
especially when its not yours!
So what if I spelled it wrong who cares I’m not n english class. N I’m not saying a standard b18 would not be great turbo. I’m just saying if ur going that route why not get that extra push from a vtec head n have that turbo give all it wants the faster it spins the better it is right n thanks guys for the help.
To decep. I know thers fucking power curves but when ur vtech power is the higher rpms n the turbo really doesn’t start kicking in till 2500 r plus then u don’t get the full affect form the turbo. U get some which will still be great but I guarantee if I put a b18a with turbo up against a ls vtec turbo same turbo set mind u it will smoke the b18a
word on the street is that the sohc vtec is the best engine to turbo! look to the left hand side of the head in front of the distributor there shoud be a spool valve! single green wire goin into it!
do you have a picture of the green wire so i can “addentifie” it?
:rofl:
Wow calm down…there is NO NEED TO BE CALLING SOMEONE THAT.
thanks man that what i wanted to know. does any one know how to adjust the valves. mine started to get real loud this morning.a friend told me that it has to be feeler gauged and it is pretty much worthless to do it that u might as well replace the caps r whatever they r.im not use to 4 cylinders ive built v8 chevy motors my whole life so i dont know exactly what i need to do to stop it
wow! I saw ignorance in this thread, genuine help and more ignorance. That sucks. lol
another good reason to stay out of tennessee, i see. thanks for the reminder
If I’m fucking wrong then correct me but being 3rd graders is fucking stupid.
90 jdm do u know what the codes r. R is there a web site I can go to get them. For the retards that have A problem with spelling I’m using a blackberry for the most part so if it comes out wrong sorry. Get a life a pay attention to the other stuff. So far nobody has wrote back n told me that I’m not actually wrong on what I said so I’m going assume I’m right untill someone corrects me.
because no one knows how to addentifie vtech heads man, slow your roll.
e: i also use a blackberry everyday, if i spelled like you do when i write my work e-mails, id be fired. just saying.
im sure there is a spell check option on your phone also, unless you have an old ass blackberry
[QUOTE=OMG Its Weasel;2123029]because no one knows how to addentifie vtech heads man, slow your roll.
im sure there is a spell check option on your phone also, unless you have an old ass blackberry[/QUOTE]
ahahahahhahaa
ignorannnnncceeeeee
This pretty sums up why no one wants to bother answering your question.
im not saying shit about people not answering the original question. im saying shit to the jackasses who run there mouth on here for stupid shit. you all keep saying shit that im wrong in what im saying. if i am then correct me. i might be wrong. but when everything i read about vtec tells u its power is in higher rpms n non vtec is lower then the vtec in my mind should be better with a turbo then a non vtec. maybe i put it wrong. i have driven stock subaru wrx n eagle talons and both of there turbos dont start to kick in till the mid 2000 rpms. if my power peaks on my b18a1 around what 5400 and the vtech peaks around 6800. dont know those figures so dont quote me on the numbers then i come to the conclusion that a turbo would be even better with the vtec cause u have longer time with boost in each gear. if that is not correct then help me to understand where im wrong thats why the threads are started not for people that dont have a life to tallk shit, and yes my blackberry has spell check dumbass but when i type im not going to go back threw everything n fix it if u can understand what i meant. like i said get a life my job doesnt require me to send emails threw my phone. and please correct me where im wrong i rather someone tell me whats right so i can fix it then to keep going on thinking that im right n it be wrong when i build. like i said if vtec turbo is not better than non vtec turbo please explain i might have the way it works wrong but im sure im right with the out come
