Can anybody give me the how’s on installing the Zendar antenna. All I know is that you have to drill into the rear window squirter, and remove the headliner. How do you remove the headliner? And all the other steps too. Thanks
TTT
I did mine last month and it was somewhat of a PITA. I loosened the back half of the headliner cause i didn’t want to take the whole thing out. Pulled out the wiper squirter(didn’t work anyways) and bent the opening on the INSIDE of the roof a little bigger. I acutally have a different brand of antenna, but I know that htye are all about the same. The hardest thing by far was getting the nut the screw onto the the bolt off of the the bottom of the antenna base. That’s why i had the bend the oof a little because i could not get to it without doing that. I wouldn’t recommend cutting a big hole out, unless you never plan on selling your teg or putting the wiper squirter back in. If you want more specific instructions, email me at slickboy_59@hotmail.com, or IM me at slckshus. Hope this helps ya! Lemme know if I can help more.
