How would i take of my distributor?What size sockets do i need?Is it 10mm or 12mm?What else would i need?
Thanks Alot!
Thanks Alot!
Tech forum…
You need a 12mm socket, screwdriver (Phillips i think), flat-head scredriver (press in wiring harness clips), and a mallet (to tap LIGHTLY the distributor off of the head). You will also need a socket extension for a couple of the bolts. Don’t forget to mark the spark plug wire locations on the cap.
For install, use a bit of silicone on the mating surface of the distributor to seal it properly.
buy a manual, it’ll come in handy for this and other stuff.
you might wanna scribe a mark where your dist and head meet
when u put it back together youre timing wont be off
