I need help… My heating doesn’t work unless im driving… as soon as im stuck at a traffic light it stops… i also can’t control
the speed that I want the heat to come out at.
I already replaced a fuse which Acura thought it could
be and I just replaced the blower resister (dunno if thats how u spell it).
If anyone has ANY clue what this could be please help me out!
Heater cant heat unless engine is running. Heater uses the engine’s coolant. As soon as the coolant gets hot, you will have heat. Im thinking its your thermostat.
could be a leak anywhere in you cooling system. cause there is low pressure, not enough to force the hot coolant through your heater core. Mine does it too, and I just have a leak in my radiator.
lol, I forgot how cold it was in VA. I used to live there (VaBch & Norfolk).
Aight, the blower motor is right above where the passenger’s feet would be. Make sure the harness connection is good. I dont know if their is a fan blower fuse, if there is… check that. If that doesnt work then i dont know. Gotta start taking it apart? I guess… :rolleyes: Maybe you need a new fan motor.
