indiglow gauge
i need help on were i can connect the wires for mah indiglow… please help me thank you…!! =):bang:
Did you check Teg Tips? Teg Tips
Check under Interior and scroll down. There’s a couple of different entries.
:up:
thanks
i know i checked that one out… but i dont have cruise control and i dunno where the brake light is can u gimme some idea where the i can put the red wire rather than the brake light?? thanks so much hommie
i didnt have cruise either so i wired it to the power on the dimmer switch, hope that helps.
thanks again
yO! man you guys have been very helpful… imma do that hope fully it works…:cool:
get a 12v test light and check da wiring of the dimmer i think its da red wid black strip… use da test lyte and turn on and off the parking light and if the light goes on and off wid it then u got it…
dont forget to get a good ground for yur indiglos and drill holes for the wires in the cluster… HTH
tell us if it works…
Go at this site… you have all wire for your car…
http://www.designtech-intl.com/
