hey guys, here’s my problem. sent my car (90 integra gs) to a shop to do a tune up. when i arrived i saw the mechanic cleaning the throttle body, to my horror it was still connected to the engine:shock::shock:… and he was spraying alot of cleaner into it, so more less all the dirt went into the iacv and injectors. When he cranked it, it hesitated and then smoked alotttt and then idled up and down for about 6 mins. When I hit the highway no power at alllll:mensa:. So my question is when im replacing do I go with the oem injectors or aftermarket? Or can I clean it using the free flow machine? and which shop in the GTA has it. thanks
there shouldnt be any dirt in the throtle body unless the car has been consistantly run with out an air filter. all that would of run into the motor would have been carbon build up which will not hurt the motor considering there will already be more of it built up on the IM, vavles and piston its self.
before replaceing your injectors which are most likely fine, I would just go get on the throtle a couple of times and give it some time to work its self out.
???, was it white smoke that was coming out of your exaust? what you seen was probly the carbon that was cleaned up being burnt off.
EDIT, also grab a can of 44K. that does wonders cleaning out fuel injector, if your realy concerned that the injector are you problem.
The smoke that came out was black…normally under hard acceleration it smokes white. Don’t understand how it may not be the injectors. So where did all the dirt go? When the TB was being clean I could see black stuff coming out. Confused.
nothing that goes through the TB goes through your injectors. the only thing that goes through the injector is fuel, the air is mixed in in the combustion chamber. so anything that got cleaned out of the TB and IM went straight into the combustion chamber/cylinder. these types of services are done quite often and they will cause some hesitation until it is completely worked through. usually the shop and or technician doing it whould tell you about that if not take it around the block to make sure it operates the same as when you initially took it in to them
:werd:
anything that ran down the intake runners would just be burned off in the combustion cycle
ok makes sense…but the car have been running over 1200 km so far and still the same. it’s mixed driving. sometimes hard and slow. before i carried it to the shop it ran really well but now it’s sluggish and have to press nearly beyond half to keep moving on the highway.
