injector?
sorry, i wasnt able to find wehat i need in the search.
i am switching over to OBD-1 in my 90 LS, so i can run a PC-Link standalone…
i was trying to find some 550cc injectors for cheap, and some guy tells me that if i am OBD-1 the largest i can run is 440cc.
here is what he said exactly…“good luck if you cant find a dist let me kno and injectors they dont make one bigger than 440cc because it is HI inpedence and 440cc is max if you run a resistor box then you can run any size 55occ,720cc,900cc,1000cc so on and so on…”
my question is, is this true, or is this guy full of it?
thanks guys:p
If your car is a 90LS then you have a resistor pack (little gray heatsink close to the vin number on your windshield but still under the hood). When you switch over to OBD1 just ensure that you splice the resitor pack in. There are instructions and pics on Hondata’s site. You have everything you need all ready if your converting to OBD1.
http://www.hondata.com/techinjectorwiring.html
thanks man i appreciatethe help:D
