I am planning to run an inlinepro manifold and was wondering if anyone else here has ran it. I was wondering if i will need to buy a 1/2 size radiator to make it work and if i will need slim fans-i plan on keeping a/c. Also does nayone have a basemap for a b17 using uberdata? This is going on my 92 gsr, Thanks!
Xenocron Uberdata Bin’s
We can prolly start with B16Ajrsc8psi221hp155tq.bin
and see how much work it will be to tune.
Make sure you don’t drive it until we get the wideband on it.
Chunk, thats a Supercharger BIN :bang:
I run an IP mani…love it.
In order to keep A/C, you will have to flip the turbo around and put the compressor on the drivers side I imagine.
I kept my full length radiator but I use two slim pusher fans for cooling now.
HTH
im with Chris on this too. I run an Inline-Pro manifold using stock radiator with 2 slim line fans.
sweet man! thats just what i was hoping for…i am pretty psyched get her running…this is the kit i am getting on saturday:
Precision Intercooler 34.5" L x 10.5" H x 3.5" D
Precision 440 injectors
Precision SC50 .63 A/R
Inline PRO turbo manifold
Inline PRO 2.5 inch downpipe w/ flex
Inline PRO intercooler piping kit(includes silicone couplers and t-bolt clamps)
Tial 50mm Blow-Off Valve
Tial 38mm Wastegate 0.3 bar(4.35 psi)
Wastegate dump tube
er… DOH!
hmm what about this one?
gsr880ccbase.bin
Stock GSR with DIY log, JR FMIC, SC61, and Precision 880’s. Stock MAP. Tuned to 6 psi, owner is to come back to tune to 10 psi when he gets his Profec B spec II working (like that’s going to happen, stupid Greddy POS)
Bigger turbo and bigger injectors…
or possibly this one?
blst550dyno.bin
B18B1,Dynoed at 208 Hp and 180TQ with bad ignition. T3/T4 7PSI, dyno and street tuned. 550 injectors 3 inch exhaust.
Find one with the same size injectors as your using so it will be at least close.
so should i choose a 12psi tune wiht 440’s over a 6psi tune with 760’s?
