I have been noticing that when I turn my steering wheel to the left all the way and back up I find just a little bit of free play in the wheel. I get inner edge tire wear bad and vibrating in the wheel when I drive and turn the wheel in either direction.
I know all of my symptoms are of worn tie rods. But I am not sure which one is more likely, the inner or the outter? Since the inner is hard to see, what is the best way to check for free play?
jack the car up and check is the best way. theres no other way.
For the outer ones, just unbolt the tierod from the spindle and move the joint around, it shouldn’t have lots of play… it should be firm for every movement and stays wherever you push it.
As for the inner tierods… the joint is hidden inside the rubber bellow. Grab the bellew and you’ll feel the joint and try pushing it up and down to see if it’s firm and once again, it should’nt have lots of play/movement.
If you’re going to replace them, don’t go cheap with ebay crap… get OEM or MOOG from www.rockauto.com.
