what does this hose connect to?
Motor is a obd0 b16a
looks like brake booster
Ive got all my booster lines hooked up anyone with this motor know? Or check?
brake booster for sure 100%
x2
x3
Like everybody else has stated that is a brake booster vaccum fitting. Do you have a better picture of the booster lines? Are you positive you hooked up all the lines up correctly?
Ive got the booster hooked up to the line in the front of the intake will put pics up soon
i hope you dont mean you have your brake booster hooked up to your pcv hose
and the HUGE vaccum leak is probably whats causing your drivabilty problems
get that hooked up or at least plugged off and see if it runs any better
^^^the front one is for PCV the rear is for brake booster
i have it plugged… i took the hose off for the pic
will get a better pic of the brake booster hoses soon
What do you have your pcv connected to? The nipple on the back of your manifold should be for the brake booster, the nipple on the front should be for your PCV.
This is a p61 manifold, but your PCV house routing is almost identical. You’ll notice that on the p61 manifold the booster nipple is also on the front of the manifold.
If you do a google image search you should be able to find some photos of obd0 b16a manifolds which are hooked up to confirm my comment above.
looks about right
