Integra Motor Mount
I have a 1990 integra and put a 96 spc r b18 in. I used the factory mounted studs that mount to the block and a motor mount from a gsr. It works but does not seem right and looks way to close to the sheet metal. Does anybody know what mount I need?
Can’t really understand your post too well, but if you aren’t already, use the mount that bolts up to the block (the one with the stud) from your old B18A, as well as the mount the bolts to the chassis (the one with the rubber) from your old motor. And if you are using the hydraulic transmission as well, you’ll need to purchase a mount hydro/cable trans mount from one of the manufacturers (Hasport or Innovative)
I’m sorry I wasn’t very clear. I typed it quickly at work. I pulled a b16 sir out and do not have the stock B18a mount that bolts to the block. The b16 block mount does not bolt up. Is the b18a different from the b16? I already have the correct rear engine mount and transmission mount. In advance, thanks for your help.
Yea the b18a block has a different orientation for the chassis mount than the b16 block mount. But they have the same bolt pattern (to the block) so you should have any problems just swapping over the b18a block and chassis mounts
The B16 SI-R from japan bolt patter did not work. Do I need the post mount from a newer b16? 96+?
No, like I said above, you’ll need the two mounts off of your B18A1.
To put into simpler words. You need to unbolt the LOWER half of the mount from your old engine and put it onto your new engoine…
LOL thanks wise_old_dragon. I no longer have the mounts from the b18a1. The engine that was previously in there was the b16 si-r. So I guess I need to find the b18a1 post mount as i have the poly mount already. Sorry I’m new to motor swaps. I typically build stand up jet ski’s.
Can’t really get any simpler than:
Dude. You need both mounts from the B18A on the driver’s side.
Thanks guys and sorry for being a little slow. The body of the car is in great shape and I hope its fun to drive and somewhat quick. I’m so close to being done. Its all in accept a few of the wires and fuel line. I’m hoping to fire it up this weekend. I wont drive it much until I get the correct mount.
It’s cool man, no apologies necessary. Just wanted to make sure you didn’t get any mixed ideas :up:
