usdm have 170hp because of their 10.1 compression ratio… that is due to the pistons alone correct? Or does it also ahve to do with crank and rod? If you were to get the JDM pistons, and just pop them in the USDM, would you get that 180hp and extra torque?
gaydm and us crank and rods are the same in the B18C
Actually, it’s 180ps, which is about 177.5hp. The extra compression will definitely help, but whether or not it’s worth it is up to you.
oh I was just curious that’s all.
thanks guys!
