91 integra LS with a 94 B18c swap with short ram intake 5 speed JDM GSR transmission with stage 2 clutch.
The car feels fine and all but if I’m going 25/35mph,the car has this power jump like it wants to go faster. I’ve replaced and or cleaned all censors and don’t know why this is happening. Maybe the car is alive and likes to go fast?
It happens at about 2/3k rpm in 3rd at 25mph and 3/4 rpm at 35mph in 4th or 3rd. Its like someone is bumping me.
I sprayed the lines to check and all lines are good and are about 1 1/2 years new. The mounts are the innovative and are all new and good so that’s not it. I did a tuneup a month ago and replaced everything. There’s no Cel at all and the motor runs grate except for the jumping at low speed. The car don’t die down at all,just normal feel with (at times)and quick push of power and it stops. But it keeps doing it tell i retch speeds of 45 and higher.
Sounds like your throttle position sensor. Verify by using an ohmeter and slowly opening the throttle. The meter should change resistance in a smooth linear fashion with no spikes or drop offs.
Yeah the TPS sounds like the case. I’m going to be buying one this week so will see from there.
Wow. this is the exact same problem I’m having. I get it at about 2.8k rpm and 3.5k rpm in 2,3,4 gears sometimes 5th. Mine is more like a slight hesitation, like I let go of the throttle.
Swapped JDM B18c(r), tuned on crome. Tried different maps but nothing seemed to fix it. Everything is running perfect except a bit of bouncing idle when its cold. I checked my tps and thought it was good since it would show 0.5v(closed) and 4.5v(WOT). I guess I Kinda assumed it would be linear if the closed and wot voltage was good.
I’ll change mine out and see if it does anything.
[QUOTE=wise_old_dragon;2177632]Wow. this is the exact same problem I’m having. I get it at about 2.8k rpm and 3.5k rpm in 2,3,4 gears sometimes 5th. Mine is more like a slight hesitation, like I let go of the throttle.
I’ll change mine out and see if it does anything.[/QUOTE]
I was reading your reply and now that i think about it,my car is doing what your car is doing. I wonder if its just a JDM GSR thing???lol But ill be replacing the TPS and seeing.
I just had to replace my TPS b/c it was triggering a check engine when I was cruising on the interstate. Im pretty sure you would get a CEL but it never hurts to test it out. Check that your FITV is shutting when the car is warm and check the IACV when the car is hot. Other than that you might need to replace the ignitor in the distributor. Make sure all the clips are really tight on the prongs.
Ryan
found a thread on honda-tech that describes our problems.
http://www.honda-tech.com/showthread.php?t=2239760 Seems like it’s most likely a tps problem. I’m going to order a Blox one and see if it helps.
My engine is a 98 so it does not have a FITV. I have checked for vacuum leaks and get nothing. I doubt it’s the distributor or ignitor, since mine are fairly new and in good condition. Also in the honda-tech thread, it seems like the O2 sensor can also cause this type of issue. However I am running in open loop and have no O2 installed.
92_LS, So I’ve narrowed down what I think it could be if it is not the TPS.
- MAP sensor
- IACV
- IAT Sensor
- O2 sensor (but I am not using one atm)
[QUOTE=PR8urVTEC;2177731]I just had to replace my TPS b/c it was triggering a check engine when I was cruising on the interstate. Im pretty sure you would get a CEL but it never hurts to test it out. Check that your FITV is shutting when the car is warm and check the IACV when the car is hot. Other than that you might need to replace the ignitor in the distributor. Make sure all the clips are really tight on the prongs.
Ryan[/QUOTE]
My TPS is not giving me a CEL because it still reads 0.5v closed and 4.5v open. But my guess is that there is a dead spot in my TPS, so when I am cruising it tends to hit the dead spot causing my ECU to cut fuel and timing. Then I get the “bucking Bronco”
Damd good info wise_old_dragon. The grasshopper is learning something new:bow:lol Yeah i to have been reading and am looking at the TPS as well. It just seems to make more seance for that to be bad as everything is new in my car. By any chance,is there a way to clean/rebuild the TPS? I to will be getting a blox but have to pay my registration next month:squint:lol Thanks again.
I bet it the map sensor bet it a lose wire
I thought it was a loose wire/map but i cleaned all connectors and looked threw the bay for loose wires and found nothing wrong. The map is about 2 months new.
Is it an oem map sensor an if it new why did you replace it was it doing the same thing
I had it replaced because the car was hesitating on take off.
were did you buy the map sensor at?
Napa
i would get oem one
Yea but its just as good IMO. But ill chick it and see if its bad. I still have the old one and will swap it out.
Why don’t you guys buy a cheap multimeter at Walmart and learn to do some diagnosis instead of just throwing out guesses and changing parts? The most likely cause is the TPS - it will not throw a code if it has a bad spot. Check its resistance through it’s entire mechanical range and look for flucuations. It will take 10 minutes to test, you will know if it;s good or bad, and will have a handy diagnostic tool for your toolbox.
You cannot diagnose it with a multimeter, trust me I tried. I still get linear values throughout, the problem is that a multimeter only measures an average and is generally not sensitive enough to measure the exact voltage at any given amount of time. Also because it would be very hard to map out the throttle position in relation to the voltage readout, you can’t be sure if any fluctuations are because of your hand moving the sensor or the fault of the sensor itself. To properly test the sensor you would need an oscilloscope to read it, and some way of mapping the position accurately (i.e. not by hand). And fyi, even a cheap oscilloscope is not cheap.
EDIT: Oops, I did not read that the OEM post was regarding the map sensor, my bad. For TPS read on,
the only way to get an oem one is to get it used… OR buy a brand new throttle body from Honda.
At $350 new, I would rather buy 2 or 3 aftermarket Omni power’s or Blox TPSs and risk my chances of one (or even two) going dead.
Thanks wise_old_dragon.
