just got block back from the machine shop
pics of block
another
is it painted blue?
what are the specs and what do you have inside it…pistons, rods, blockguard etc?
not it is not painted blue it is not painted at all stock color as far as whats inside is
83mm cp pistons 9:1 compression
eagle h beam rods
king main and rod bearings
circuit works oil pump gear
aebs sleeves
NICE! going in a 2nd gen? We’ll have to run some time. My friend lives on pine island, I’ll be going down there when she’s up and running. darton sleeved LS/vtec.
yep going in a white 2nd gen . sounds like a date
hoping to have it up and running tomorrow night friday mourning at the latest
we’ll have twins, mine’s white too. mine won’t be ready that soon though. whats the turbo setup?
t3/t4 cold side .50ar and hot side .63 what goodies does your block have in it
how long till your is done
so those are actually sleeves thats not sleeves with a block guard? if so thats awesome mind if i ask how much that set you back?
HELL YEAH!!! great choice of sleeve’s. have fun with that AEBS block.
the sleeves set me back right around $1000 all together
my problem is that every time, I think I’m ready to get it running again, I sell something and upgrade. my setup as of rite now:
Darton sleeved LS
84.5mm 9:1 comp JE pistons
LS crower rods
LS crank
Toga oil pump
ACL bearings
B16a head P&P
ferrea valves
GSR cams w/ aem cam gears
Typer Valvesprings w/ crower titanium retainers
Skunk2 Mani(soon to be replaced with STR/HP/JG manifold)
STR 70mm TB
(got about $2300 into the longblock)
SSautocrap mani(soon to be replaced with a top mount)
Trust typeS wastegate(yes wastegate)
SC61e
huge bar & plate FMIC(24x12x3 core)
2.5" IC pipe
crushed 1gen dsm BOV
(got about $2100 into the kit)
1000cc RC engineering injectors
chipped P28 with uberdata and datalogging cable
m-300 wideband
z-10 traction bars
(got $1350 into other ish)
prices are for clemsonteg.
is it a ssautocrap/xspower turbo? If it is, I doubted that turbo on my friends LS crx. It works nicely, 7psi by 4k. he made 187whp, 178ft/lbs at 7psi with a semi-street tunned map and a 185kmile LS. A/F is nice and rich in the high 10’s, low 11’s(under boost). It has a lot more in it. when I turn the boost to 11psi and spend some time messing with the timming I’ll post his dyno sheet.
yes it is i know everybody talks crap about it but it has done me no wrong . but i am looking into upgrading the turbo so i can have the whp that i want and i don’t think the one i have now is going to do it
