Hey all I just finished installing my new bushings (ES) in my control arms and my Koni/GC (550f/450r). Just curious, for all of you who are running Koni/GC how low are you in the front and how much travel do your Konis have? Heres my story: I installed everything at max height so I could adjust from there. I measured and decided how much lower I wanted to go and adjusted accordingly. At first I went way too low by mistake and after driving the car for about 1/8 mile I bottomed out both the front shocks after hitting a dip in the road. After parking the car and getting out to check I saw that the front was way too low so I adjusted it up about a half inch and moved the circlip on the konis to the top position. Now I have it adjusted to a good height and haven’t bottomed out again yet… Even though it is at a good height for me there are probably only two inches of travel for the konis until they bottom out. So this makes me kind of nervous only two inches of travel… Is this normal? Should I get GC extended tophats? Or should I not worry about it? I am on 550f/450r spring rates. Thanks.
top hats wont hurt. that sounds about right though nothing to worry about. i think i have even less then that but i might be a little lower.
Damn son. Have you ever bottomed out your konis? Are you still on 450f/350r ? (found your rates in the suspension and pics thread) And, you have extended top hats in the front? What kind, how much, and where did you get them from? Oh, and nice car! I just saw a pic of it.
yeah, with typical “sleeve type” coilovers, you’re going to lose more and more suspension travel with the drop. Koni shocks and GC coils are rather durable, though. i have the snap ring on the top perch on mine, and the spring perch at the absolute lowest point, and have about 2" of travel. I WOULD invest in the Ground Control top-hats, which can be purchased at any number of online sellers, i believe weksos has them for sale on this site. but i’m not going to bother with it, as I’ll be taking the Koni/GC setup off within a year or two, potentially. there’s absolutely nothing wrong with mine, and i probably won’t even sell them. they’re GREAT for DD’s who see occasional autocross/track events. but I’m going to be buying something made specifically for track use. I’ll keep the Koni/GC setup for another DA.
Remember that wheel travel and shock travel are not the same. 2" of travel at the shock will give you >2" of travel at the wheel.
I typed up a basic rundown of what everyone should be doing if they’re concerned more with appropriate travel than with looks: http://www.g2ic.com/forums/showthread.php?t=200654
Hey thanks for the replies redtegra, imcnblu, and Colin. I just read what you wrote on that other thread Colin, thanks for that. I will probably try it, and also get extended top hats when I have the funds. I was very concerned the first day when I actually bottomed out the shocks but I realize that was my fault for setting it too low. Now that I have it set higher it feels AWESOME. I am getting it aligned friday so before that I will do the zip ties on the shocks and set it at the exact height necessary to give the shocks the travel they need.
just to answer your question i’ve bottomed out the shocks countless times. the roads in my province are pretty much mine fields and you constantly have to swerve around everything. however on a normal road like you would find more often in the US i would probably never bottom out the shock. and yes i still have the 450f/350r rates. would like to try out 550f/500r but that’ll have to wait for another time. extended top hats are the ground controls and i got them locally. and thanks! you definitely wont be disappointed with this setup.
I was pretty dead set on getting the Koni/GC with top hats setup but realized that the PIC full coilovers would be the same price.
The thing is that I believe the PIC sets lowest spring rates are like 10k/8k while you see people with 450/350 on the Koni/GC setup. I thought that as you lower the Koni setup you change the spring rate.
Can anyone elaborate on just how much the spring rate is changed with lowering? I want to eliminate wheel gap so ~2.5-3in.
[QUOTE=omga14;2133335]
Can anyone elaborate on just how much the spring rate is changed with lowering? I want to eliminate wheel gap so ~2.5-3in.[/QUOTE]
Spring rate doesn’t change when you adjust ride height, spring rate is determined by the springs themselves, so they’re a constant.
Some people like to run a stiffer spring rate if they will be lower in order to reduce the amount of travel when hitting bumps, thus reducing the chance of bottoming out. But there’s no rule for something like that, it’s trial and error and personal preference.
Thanks for that information. Now I need to find someone who has a ride with high spring rates so I can feel what that’s like and make my choice.
The Koni/GC setup does seem to get nothing but praise in every forum.
