Knocks when cold start
Hello there friends of the G2. I have a slight knock when I first start the car when it is cold. Some people tell me no big deal and others say I may want to look into it. I’m wondering if I can get some advice from you guys. I’ve done turbo kits, cams, timing belts, clutches, motor swaps, and just about any bolt on you can think of but I’ve never actually taken a motor apart beyond a handful of head gasket jobs I’ve done. The whole clay measuring thing and getting new bearings and do I need to machine the block and just all this stuff I’ve searched but always get mixed answers about.
On to the point I just want to know is it worth replacing the timing belt, water pump, all major gaskets, and possibly swapping on a fresh head that I want to give the full crower treatment or look into a complete rebuild. Not asking for a how to but just advice in what direction I should take. No turbo in my future I just like to drive my bitch like the whore she is and need to make sure she’ll handle it. Thanks guys.
O and I drive the car EVERYDAY. Been like that for 4 years and wouldn’t have it any other way.
if its coming from the top then its ur valves and you just need to readjust them. if its from the bottom then if best to send ur crank shaft the machine shop and change all seals and bearings.
My engine has 333,000km’s on it and it “knocks” every morning in the -10c weather. After the oil is warmed up she’s just fine and I send her to redline every day. My mustang 5.0 with a fresh rebuild also knocks when cold… so do many newer vehicles. I wouldnt worry about it, or at the most I’d drop the pan and do a set of rod bearings. It’ll take a afternoon…
one thing i for got u might just need thicker oil.
Well i run 10w40 all year round and i know compression is dam good so if bearings all i need and is simple as dropping the oil pan that would be awesome. Also no offense but i know the difference between valve chatter and a knock in the block so that to me was just a weird ass response but thanks anyways at least i got responses. honda tech was a wasted post
Valve chatter is more of a mettalic clack or chatter and a bottom end noise would be more of a solid knock. My GSR had horrible valve chatter until i got the valve lash re adjusted. My car when it is cold in the morning will knock its no big deal it is just because all of the oil has sank down into the oil pan and it takes a while for all the parts to get lubricated.
Alright for now then I suppose I will pull the head for my refreshed one and just make sure to adjust the valves and hopefully it’ll be all good. Thanks for the advice guys.
what weight oil are you using. have you tried to switch to something a little thiner
At 10 degrees, you don’t want thicker.
Correct.
i always use 10/40 seems to hold up better then 10/30 idk why just does in the winter time in virginia when it starts to drop to freezing temps at night ill change to 5/30 but i been in florida for a lil bit so im stilll running 10/40
