leaking power steering
so my car started to make a horrible screeching sound a few weeks ago. i figured i just needed to grease the bearings or sum thing. after doing a check i found that i had really low fluid. i filled it up and the screech went away. but i got to thinking…fluid doesnt just disapper. i dont have any big signs that i have a leak but there is random spots of fluid where ever i park. i looked at it today after i had driven a while and when i opened the reservoir it had a million and one bubbles. so i know theres a leak for sure. but i have no idea where to start looking. any ideas??? thanks for wat ever help you can give!
First check the pump itself and around the reservoir, and the hoses connecting them.
Follow the lines down the side of the engine that go back to the rack.
On the passenger side, check the speed sensor on the tranny. There are 2 PS hoses that connect it to the rack.
If you haven’t found the leak, jack the car up as high as you can and get underneath (use jackstands)
Check for fluid around the bellows boots. They’re the dust covers at each end of the rack that cover the inner tie rods.
Check where the hard lines connect to the rack. There’s a cover on the drivers side that you’ll probably need to remove to check where the lines go into the valve body.
-Let us know what you find. If there’s a ton of fluid all over the underside, you might have to clean everything first. After it’s clean, go for a short drive or just turn the wheels back and forth a bunch of times and then look again.
