Well,
I seem to have misplaced my KEY for my 4 special lugs. does anyone have any ideas i needs to get these off without damage to the wheels or stud, i dont care about the key lug. i need to replaced my brakes soon.
i feeeeel shafted
Well,
i feeeeel shafted
Use a tight socket and try to pound it onto the lug nut, then try to unscrew it. Works for me when I lost my lug nut key.
Also, you can take it to a tire shop and they’ll have numerous keys for you to try… good luck.
tire shop…thats what i did. the guy even gave me the key for free!
tire shop or towing company can get them off. tow truck drivers usually have a lug kit, its softer metal so when they hit it on it sorta molds around and “makes” a key… sounds strange but thats what they do if you don’t have your key and have a flat.
u might try auto zone adavance oreillys r go to walmart n see if they can pull it r tell u where they got theres. i work in the tire lube garage at walmart and we have a tool that looks like a key that u take a impact an run it over the lug and it works like one of those bolt removers. it will screw up the old lugs. i would do that and order some new ones and put the key number up so u can order one from the dealer the next time u loose one
what kind of lugs
if its spine drive
thin wall 17mm 12point works to a point. also im sure any tire shop has a few… if not any spinedrive key works from brand to brand
wheelworks/americantire/ break them off for $10 a peice if that is your last choice
i don’t see how this could work. the “key” would just strip once you try and turn it.
if it’s an inverted lug, just use an air chisel. carefully
or yeah, better take it to a tire shop
if it looks like a hex or star key then you might be able to fit the 3/8 square part of a rachet in it.
I broke my key and couldnt drive out to search so i got creative and figured out the 3/8 square part the you attach sockets to fit in so i added a short extention to my rachet and it work.
most car part places have lug remover kits, we have to use them all the time at school, its a socket looking thing you pick the one that fits on your lug and hit it with a hammer, then it just turns off with a ratchet, i think they cost 30-50 bucks for the set, this is what they look like
if its a oem locking lug take it to any honda/acura dealer. most will pull them off for free
I just recently came into this issue while doing the brakes on my TL, guy at honda was cool as shit:rockon:
